1999 GMC Safari Heater core removal
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
RMT4279
  • 7 POSTS
I need instructions as to how to remove the heater core.
Sep 2, 2010 at 5:02 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you for your donation.Do you need instruction's for the main heater core or the auxiliary heater core?Let me know so i can get you the correct information.
Sep 2, 2010 at 5:13 AM
RMT4279
  • 7 POSTS
Instructions for the main heater core. Do I need to remove complete assy inside
Sep 2, 2010 at 5:25 AM
SATURNTECH9
  • 30,869 POSTS
Heater Core Replacement REMOVAL PROCEDURE 1. Remove the air cleaner. 2. Drain the engine coolant. Refer to Draining and Filling Cooling System in Engine Cooling. 3. Remove the heater hoses. 4. Remove the screws that retain the cover to the heater assembly. 5. Remove the screws and the straps that retain the heater core to the heater assembly. 6. Remove the heater core from the vehicle.
https://images.2carpros.com/forum/automotive_pictures/416332_1999_gmc_safari_heater_box_1.jpg
There is the instruction's in the diagram number 2 and 3 are the heater hose's you need to remove.Doesn't look like you have to take the dash apart look's like you just have to take the heater box apart in the engine compartment.
Sep 2, 2010 at 5:37 AM
