1999 GMC Safari fuel pump
139,000 MILES • 6 CYL • AWD • AUTOMATIC
KRISMCALLISTER
I recently changed my fuel pump because my van broke down on the side of the highway. I was always able to hear the fuel pump start once the key was turned on and I could no longer hear it. I assumed it was the fuel pump. Once changed I still could not hear nor start my vehicle. I was wondering if there could be a problem with my wiring. If so, do you have a diagram or an answer to help me figure this out?
May 8, 2008 at 10:49 AM
BLACKOP555
  • 10,386 POSTS
i would start off by checking the fuel pump relay which is located in the underhood fuse/relay box.
connect a test light between fuel pump test terminal and ground turn the ignition on the light should illuminate for 2 seconds then go out, if not check the relay.
Also check the fuel pump fuse. if htose are both good check for a short in the fuel pum wiring harness.
May 8, 2008 at 11:48 AM
