the air only comes out of the deforst vent. ac works but does not come out of front of ip not matter what i have the control set to
Aug 25, 2009 at 10:39 PM
2CARPRO JACK
✓Experienced Mechanic
There is avcuum line that goes from the passenger side of the engine compartment to the drivers side of the engine where it hooks to a vacuum source.You will find itis broken , most likely on the engine.If you pop the hood. the small black plastic line will come out of the firewall on the pass. side, and cross to the drivers side of the engine.
Aug 26, 2009 at 1:04 AM
