1998 GMC Safari miss in #4 cyl
340,000 MILES • 6 CYL • AWD • AUTOMATIC
NRN319
I have a miss in #4 cyl. at idle its ok. when you raise the idle a little the spark to # 4 cyl stops. No spark at wire. It has new plugs,cap rotor,and wires
Neal
Jan 26, 2008 at 6:56 AM
BLACKOP555
  • 10,386 POSTS
You may have a faulty ignition module. since everything else seems to be taken care off. and since you say spark stops it wouldnt be an injector.
Jan 26, 2008 at 9:12 AM
NRN319
[quote:b0d768d0cd="blackop555"]You may have a faulty ignition module. since everything else seems to be taken care off. and since you say spark stops it wouldnt be an injector.[/quote:b0d768d0cd]
is that in the distributer
Jan 27, 2008 at 4:15 AM
BLACKOP555
  • 10,386 POSTS
should be on the side of the distributor.
Jan 27, 2008 at 6:39 AM
