1998 GMC Safari I have 2 noises I was hoping you could give
1998 GMC SAFARI
232,000 MILES • 6 CYL • 2WD • AUTOMATIC
RGKOTRAS
1st noise just started about a week ago It is a high pitched noise when the van is running. I have crawled around the van while it was running and it seems to be coming from the gas tank area. About a year ago I hade a new delco fuel pump installed. Is this a sign of bad things to come?
2nd- Every so often I have a popping noise in my right front. My steering is good no shkes or wobbles. Tires seem to wearing well I am just concerned.
Thanks for you help
May 25, 2010 at 1:31 PM
SERVICE WRITER
  • 9,123 POSTS
You picked the brand I would have. Check the fuel pressure, If it is good then ride it out. IT may do that for years or another week. I doubt the whine will be a warranty reason.
Check your ball joints, frame mounts for play. Sway bar links and frent end steering shoul;d get checked for play.
May 25, 2010 at 1:54 PM
