1998 GMC Safari Fuel pump
1998 GMC SAFARI
154,666 MILES • 6 CYL • 2WD • AUTOMATIC
BOSCHULD
I have power at the fuel pump replaced pump with a new one and the pump is not running?Ieven took the pump out and hooked it directly to the battery and no whining?
Nov 28, 2008 at 3:12 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Was new pump grounded at the time you hooked to batt? if so faulty pump. Have you tried old pump?
May have ground issue at pump.
Nov 29, 2008 at 3:46 PM
BOSCHULD
Yes it was a grounding issue I replaced the fuel pump connector and cleaned all the grounding connections and check the resistance of all the wires.checked the old pump also no good.
Nov 29, 2008 at 5:36 PM
DOCFIXIT
  • 18,828 POSTS
So it is running?
Nov 30, 2008 at 1:33 PM
BOSCHULD
Yes it is running.I got up Saturday morning and fixed it but the fuel gauge isn't working will have to take a look at it some more.thanks
Nov 30, 2008 at 2:38 PM
DOCFIXIT
  • 18,828 POSTS
Guage wire in that terminal if need color code let me know
Nov 30, 2008 at 3:09 PM
