1998 GMC Safari crank shaft censor
135,000 MILES • 6 CYL • AWD • AUTOMATIC
BIGNICK101
i have the machine and the code is saying the crank shaft sensor is intermitent, what does it mean? i changed the crank shaft sensor and it still does the code still reads the same.
Mar 9, 2008 at 12:20 PM
PEAR69
  • 1,482 POSTS
When you change the crank sensor you should have a crank relearn proceedure done to the computer at a dealer. Your problem sounds like the wires leading to the sensor may be loose or starting to fail. Trace them back and look for any problems.
Mar 9, 2008 at 3:34 PM
