1997 GMC Safari Hooking up the starter
13,500 MILES • 6 CYL • 2WD • AUTOMATIC
BARBERG
How do I hook up the starter motor, there is three wires one from battery(black), one red thin wire, one purple. I disconnected the after market alarm that was causing the ignition not to operate
Nov 20, 2009 at 2:08 AM
BIGJIM79
  • 239 POSTS
[quote:f374645ba4="BarberG"]Electrical problem
1997 GMC Safari 6 cyl Two Wheel Drive Automatic 135,00 miles
How do I hook up the starter motor, there is three wires one from battery(black), one red thin wire, one purple. I disconnected the after market alarm that was causing the ignition not to operate[/quote:f374645ba4]
Purp;e goes to big bolt on starter, red to small one on solenoid, black to bellhousing bolt that holds on starter.
Dec 1, 2009 at 5:12 PM
