1997 GMC Safari fuel pump problems
19,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPIDERWEB40
van stopped running, and was diagnosed by a dealership as a faulty fuel pump. I purchased a fuel pump from an auto parts store, and replaced the old pump. The van will crank but will not start, I've check connections, relays, etc. Can a clogged fuel filter be the culprit?
Aug 23, 2009 at 4:53 PM
  • 75,988 POSTS
Verify if the new fuel pump is producing the correct fuel pressure, inspect the fuel filter-if both good-check for injection pulses. No pulses =No fuel
Aug 23, 2009 at 5:54 PM
