1996 GMC Safari i hit my brakes and the pedal presses back
FATHEAD69420
Brakes problem
1996 GMC Safari 6 cyl All Wheel Drive Automatic
i hit my brakes and the pedal presses back and wont stop sometimes its got the hydroboost setup instead of vacum assist but i replaced the hydroboost and power steering pump and was wondering if the master cylinder could be the problem or maybe something else but i figured those componets might be it but i need another oppionion
Feb 26, 2010 at 10:21 AM
  • 75,988 POSTS
If your pedal is pulsating -could be the brake rotors are warped
Feb 26, 2010 at 10:40 AM
FATHEAD69420
well the rotors are brand new so are the calipers and brake lines
Feb 27, 2010 at 7:45 AM
  • 75,988 POSTS
Could be coming from the ABS unit if it has one
Feb 27, 2010 at 8:22 AM
MUDDUCK272829
[quote:b1a1da4ae7="fathead69420"]Brakes problem
i hit my brakes and the pedal presses back and wont stop sometimes its got the hydroboost setup instead of vacum assist but i replaced the hydroboost and power steering pump and was wondering if the master cylinder could be the problem or maybe something else but i figured those componets might be it but i need another oppionion[/quote:b1a1da4ae7]
If u hear noise(usually pretty loud so its very noticeable) and the pedal is pulsating rapidly and ure brakes are not responding, Its the abs sensors in the wheelbearings. Very rare does the abs unit go bad. unfortunately, u have to buy the wheelbearing hub assembly to fix it wich could be costly since u still dont know wich side is doing it. (front left or front right) try unplugging the sensors 1 at a time to see which one is giving u the problem.
Mar 4, 2010 at 6:25 AM
