1995 GMC Safari Starting
LARKINSB
Engine Mechanical problem
1995 GMC Safari 6 cyl All Wheel Drive Automatic 160K miles
I have a problem starting my van without the use of starting fluid. Once started it runs like a top as always. It just won't start initially without help. I changed the plenum gasket and cleaned up the inside with carburator cleaner. Could this have affected the injector or pressure regulator? Also the van has been sitting all summer. This problem did not exist prior to the gasket change.
Nov 29, 2009 at 12:32 PM
BIGJIM79
  • 239 POSTS
Sounds like the either temp sensor or IAC valve
Dec 1, 2009 at 5:07 PM
