1995 GMC Safari power windows
1995 GMC SAFARI
155,000 MILES • 6 CYL • AWD • AUTOMATIC
JB8103
Power windows do not operate. Checking voltage across fuse block terminals, there is no voltage at this position. Vehicle is running during check. How in the world can this happen?
Other fuse positions check out OK, except cigarette lighter, which reads 10 volts.
Vehicle equipped with aftermarket alarm system. This controls door locks.
Dec 28, 2007 at 12:48 AM
2CARPRO JACK
  • 11,533 POSTS
Behind the battery are some power feed wires. They get corroded when the acid leeches up the cables. Seen this before. Tets at connector to verify no power
Dec 28, 2007 at 11:34 PM
JB8103
OK, according to Mitchell Manual wiring diagram, there's a battery junction block right there. Is that the connector you mean, on the junction block lead?
Dec 29, 2007 at 1:25 PM
JB8103
Here is an underhood illustration, left side of firewall
Dec 29, 2007 at 2:20 PM
2CARPRO JACK
  • 11,533 POSTS
That looks like the one
Dec 30, 2007 at 12:45 AM
JB8103
Thank you, I will check that ASAP. Or ASAISS (as soon as it stops snowing).
Dec 30, 2007 at 5:42 AM
