My car gets no heat unless I am traveling at high speeds for about 10 min. My temp Gauge reads high 235, once the van runs for a while but does not overheat or change performance. I changed the thermostat, but still no change, I was told it could be my water pump, or my heater core is cloged. I see no leaks under van overnight. also, coolant in reservour doesnt change much when van is hot. What do you think it could be?
Jan 10, 2010 at 7:58 AM
