1994 GMC Safari Sputtering and no acceloration
1994 GMC SAFARI
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
JENHART
Hello! I am needing help diagnosing my sick 1994 Gmc Safari. About a month ago, I changed the oil and then went on vacation for 10 days. Upon returning, I drove the van about 30 miles, filled up with gas and drove home. On the way home I noticed the van was cutting out slightly, but it stopped as soon as I pressed the accelorator. This stalling got continually worse until the van refused to start. I changed the spark plugs, plug wires, distributor and rotor, and vacuum lines. I tested the fuel pump and am getting 60 psi on the tester. The coil is also working properly and I have made sure the transmission fluid is filled. I did also add some additive to the fuel tank after the stalling started as I supposed there might be water in the tank.
I have gotten the van to start, but when I press on the accelorator, it acts like it is losing power and begins to cough and sputter. When in idle, you can rev the motor and it does not sputter, but acts like it doesn't want to rev.
Any help would be appreciated!
Aug 12, 2008 at 8:46 AM
69 MALIBU
to jenhart's question
Sep 18, 2008 at 11:13 AM
