1994 GMC Safari No Overdrive
157,000 MILES • 6 CYL • AWD • AUTOMATIC
ERIC NATIVIDAD
I was wondering if any of you encountered this problem of no over drive shifting and delay down shift during a stop. Is there any controller for the tranny that needs checking.
Jun 28, 2009 at 10:53 AM
FATBOY46
  • 5 POSTS
TCCS- torque converter control switch.... switch is cheap.. labor is not. switch locks up the TC to give better mileage. when it doesnt work properly, it tries to stall when you stop, like having the clutch engaged in a standard shift.. or it will suddenly release... that would explain the slow down shift.. and the no-OD shift..
Jun 28, 2009 at 11:11 AM
