1994 GMC Safari
WILLIAMMCMAHAN
Electrical problem
1994 GMC Safari 6 cyl Two Wheel Drive Automatic
I HAVE REPLACED THE FUEL PUMP AND I'M NOT GETTING ANY POWER TO RELAY ALSO REPLACED RELAY. I ALSO CHECKED THE HARNES GOING TO TANK, NO POWER. I WAS TOLD THAT THE OIL PRESSURE SENSOR MAY BE BAD, SO I PUT A NEW ONE ON, NO CHANGE, IS THEIR A FUSE THAT I MAY BE MISSING.
Sep 6, 2008 at 3:00 PM
WILLIAMMCMAHAN
[quote:7d545d119a="williammcmahan"]Electrical problem
I HAVE REPLACED THE FUEL PUMP AND I'M NOT GETTING ANY POWER TO RELAY ALSO REPLACED RELAY. I ALSO CHECKED THE HARNES GOING TO TANK, NO POWER. I WAS TOLD THAT THE OIL PRESSURE SENSOR MAY BE BAD, SO I PUT A NEW ONE ON, NO CHANGE, IS THEIR A FUSE THAT I MAY BE MISSING.[/quote:7d545d119a]
Sep 6, 2008 at 3:01 PM
