1993 GMC Safari fuel filter
1993 GMC SAFARI
SID PAPAGEORGIO
Engine Performance problem
1993 GMC Safari 6 cyl Two Wheel Drive Automatic
how do you change the fuel filter and where is it located?
Jun 21, 2010 at 10:58 PM
In-Line Fuel Filter
https://images.2carpros.com/forum/automotive_pictures/12900_filter_3.gif
WARNING: To reduce the risk of fire and personal injury when the fuel line is disconnected, cover the fuel line with a shop cloth to collect the fuel, and then place the cloth in an approved container. REMOVE OR DISCONNECT Raise vehicle. Disconnect the fuel lines from the filter. NOTE: Use a back-up wrench to prevent filter, O-ring, or fuel line damage. Remove the filter from the car. INSTALL OR CONNECT Install the new filter in position loosely. Using new O-rings, install the fuel lines into the filter. NOTE: Use a back-up wrench to prevent filter, O-ring, or fuel line damage. Torque line fittings to 30 Nm (22 lb-ft). Secure the filter to the vehicle. Lower the vehicle. START the engine and inspect for leaks.
Jun 21, 2010 at 11:08 PM
