1993 GMC Safari black smoke out tailpipe
1993 GMC SAFARI
300,000 MILES • 6 CYL • 2WD • AUTOMATIC
ENGINEPRO
Engine starts on clear flood mode...gas pedal alll the way down....wide open throttle.
Engine does not idle well.
Black smoke out the tailpipe.
Thanks
May 24, 2010 at 3:29 PM
Inspect and test the injectors, fuel pressure regulator and coolant temperature sensor.
May 24, 2010 at 3:34 PM
ENGINEPRO
[quote:9161114152="rasmataz"]Inspect and test the injectors, fuel pressure regulator and coolant temperature sensor.[/quote:9161114152] Thanks for your help.
I will check these out in the morning and let you know what is happeneing.
May 24, 2010 at 3:56 PM
