replaced fuel filter and pump 2 months ago... started engine and started fine then started to sputter... when I pumped it it tried to rev but sputtered out then gradually got worse.. now it will not start... checked fuel floe to filter... pump is pumping... when I removed fuel filter no fuel ran back down from engine and out of line, so problem must be after the fuel filter? removed fuel filter and blew it out... replaced it and still won't start... What do I do now? would starting fluid help to get it primed and sucking fuel? are there fuel injectors on the is year 1992?
Jun 29, 2010 at 3:14 AM
