1990 GMC Safari FUEL PUMP
125,632 MILES • 6 CYL • AWD • AUTOMATIC
TECH MECH
Vehicle was running fine, turned off unexpectedly and will not turn on again, turns over fine, has spark in wires but no fuel coming up to carburator. Already checked fuel filter and all fuses. Is there a fuel pump realy or is the pump bad???
Jun 8, 2008 at 10:33 AM
  • 75,988 POSTS
Do you hear the fuel pump come On for 2secs when key at run position? if so check the fuel pressure with a fuel pressure gauge and comeback with the readings.
Jun 8, 2008 at 11:35 AM
