1990 GMC Safari battery
MANCONFUSED39
1990 GMC Safari 6 cyl Four Wheel Drive
I would like to know why the battery gage reads that the battery is low. I have replaced the battery, starter and the alternator. Once i remove the positve from the battery the van turns off. I place the positive back on an the battery reads low as if it is not charging. Please help.
Aug 9, 2010 at 1:05 AM
MMPRINCE4000
  • 8,548 POSTS
Do not remove the battery cables when engine is running, this can damage alternator.
Take car to most autoparts stores and have charging system tested for free.
Aug 9, 2010 at 1:12 AM
MANCONFUSED39
Thank you. I did take the van in for testing and was told that everything was charging ok. But they did not have answer to why the battery meter would stay on low.
Can it be possible that the meter is broken?
Aug 9, 2010 at 1:19 AM
MMPRINCE4000
  • 8,548 POSTS
Yes.
Measure voltage at battery terminals with DVOM.
With engine running, it should be 13.5-14.0V. With engine off, it should be 12.0- 12.5 volts.
Aug 9, 2010 at 1:26 AM
MANCONFUSED39
Can I repair the battery gage meter?
Aug 9, 2010 at 1:49 AM
MMPRINCE4000
  • 8,548 POSTS
Probably not, but aftermarket AMP and Voltmeters are available everywhere.
Aug 10, 2010 at 1:22 AM
