1997 GMC S15 o2 sensor
1997 GMC S15
142,300 MILES • 6 CYL • 4WD • AUTOMATIC
JRZ1978
i've changed the o2 sensor like 5 times and the same one keeps going bad and when it gose bad it missfires and runs to lean and low volteg and engine light comes on again what could cause the o2 sensor to go bad
Oct 23, 2008 at 4:16 AM
SWILLIAMS
  • 597 POSTS
How are they failing? Does the engine use any oil or coolant? What kind of fuel mileage are you getting? Do you smell gas under the hood?
I ask because it is not a common thing for O2 sensors to fail that fast. Excess oil use or a coolant leak into the intake could be enough to damage them. Excess gas from a leaking injector or faulty pressure regulator could also do it.
Oct 24, 2008 at 8:39 AM
