1997 GMC S15 cAMBER ADJUSTMENTS
UNTAMED2
Drive Train Axles Bearings problem
1997 GMC S15 Four Wheel Drive Automatic
i RECENTLY PUT A 2 INCH SUSSPENSION LIFT ON MY 97 GMC S-15 JIMMY I ALSO PUT TALLER TIRES ON I HAVE PURCHASED SOME 2 INCH WHEEL SPACER'S when i put them on my tires lean in at the top and my camber adjustment is maxed out what can i do to get my camber back in allignment ? Is there some adapter that can be perchased to give me an additional 1 to 2 inch of camber adjustment?
Feb 17, 2010 at 4:53 AM
HMAC300
  • 48,601 POSTS
soemtimes due to the lift you have to put in shorter a-arms on the top side to bring the camber back into adjustment. Look in one of the truck magazines i'm sure you will find what youare looking for. Or go to www.powerblocktv.com and check one of the things like the extreme or trucks show to see one of their advertisers there. Or another on speed tv is truck university i think it is they've done al ot of stuff like that on the tv show and have the suspension people that you can get alhold of.
Feb 23, 2010 at 3:31 AM
