1995 GMC S15 no start
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
LAH43
95 sonoma 4.3 throttle body, second occurence, now in no start mode. pulled bed to access pump wiring, no voltage to pump key on or crank, pump runs with external voltage supplied. other notations, no injector action while cranking. has strong consistent spark
Dec 3, 2009 at 9:06 AM
BMRFIXIT
  • 19,053 POSTS
Turn key on do you have check engine light on
you should if not start by checking fuses and relays and fusible links
!!!! fuse ,relay , wiring harness and or short ,
faulty PCM
Dec 3, 2009 at 9:46 AM
