1994 GMC S15 Won't start
TEECO
Engine Mechanical problem
1994 GMC S15 6 cyl Four Wheel Drive Automatic 150k miles
My Gimmy was running great. I started it up and drove to get gas about 300 yards and it would not start up.
Replaced the rotor and cap and the fuel filter. The fuel pressure is now 60 psi. Still will not start. The anti freeze level is low. No water in oil.
Mar 10, 2010 at 7:51 AM
JDL
  • 16,098 POSTS
Hi, if it cranks good but won't start, have a helper crank it, while visually check for spark at the plugs. Any trouble codes? Your obd1, you should be able to check for some mil codes yourself. Is there an injector pulse, engine cranking, use a noid lite.
Mar 10, 2010 at 7:57 AM
