1994 GMC S15 SWAP
19,800 MILES • 6 CYL • 2WD • AUTOMATIC
NAILNBOARD
WILL AN 1992 2.8 LITER ENGINE SWAP WITH AN 1994 S-15 4.3 LITER. IF YES, WHAT MODS WILL HAVE TO BE MADE TO THE TRANS HOUSING TO BOLT RIGHT UP? THE OLDER IS WITH AN 5 SPEEED AND THE NEWER IS AN AUTO THANKS
BOTH ARE FROM THE SAME GME S15 LINE
Feb 26, 2010 at 5:10 AM
HMAC300
  • 48,601 POSTS
there are way to many mods that have to be done to make this ok. The transmission unless you have the universal trans will not work along with torque converter, computer and other various things. Just get antoher 4.3L or rebuild the one you have....
Feb 27, 2010 at 4:43 AM
