1993 GMC S15 windshield wipers
BRENT5862
Electrical problem
1993 GMC S15 6 cyl All Wheel Drive Automatic
my wipers won't shut off
Oct 14, 2008 at 2:00 PM
RACEFAN966
  • 5,029 POSTS
It is probably the wiper pulse board. Go to you local parts store to buy it and it is just unplug the wire harness to it and three torx screws to replace it. Let me know how it goes.
Oct 14, 2008 at 2:15 PM
BRENT5862
I did a new wiper pulse board, it worked for a few minutes than would not shut off again. The pulse board I have has only one screw in the middle.
Oct 14, 2008 at 2:26 PM
RACEFAN966
  • 5,029 POSTS
Ok so the pulse board should be good then. It can't be the wiper motor because it would then quite instead so the only left possibility is the combonation switch or multi function switch.
Oct 15, 2008 at 2:58 AM
BRENT5862
Thanks I will try the combination switch, because I didn't think it would be the motor either. I will let you know the outcome.
Brent
Oct 15, 2008 at 2:40 PM
RACEFAN966
  • 5,029 POSTS
Ok that sound good. Till later then
Oct 15, 2008 at 2:56 PM
