1993 GMC S15
205,000 MILES • 6 CYL • 2WD • AUTOMATIC
MICHAELCANNON88
my truck keeps flooding out when i try to start it with accelerator to the floor it turns over but floods out again, have changed fuel pressure regulator, map sensor, IACV, plugs and wires. Could it be one of the injector pipetts stuck open if so how could i unstick it w/o replacing the part?
Apr 21, 2009 at 3:47 AM
  • 110,251 POSTS
It could b a stuck injector, but I don't think one would cause the engine to die. Have you checked the fuel pump pressure? I realize you replaced the regulator, but there could still be a problem.
Jul 1, 2009 at 11:42 AM
MICHAELCANNON88
I have replaced the fuel pump as of 1 week ago, still have the problem, and also the fuel pump relay was replaced
Jul 9, 2009 at 8:34 AM
  • 110,251 POSTS
It sounds like you have been very thorough. I'm still courious about the fuel pressure. Regardless, if you have good fuel pressure and spark to the plugs, then we need to look elsewhere. With 205K on the engine, have you considered low compression as a problem? Have you checked compression?
Jul 9, 2009 at 10:28 AM
MICHAELCANNON88
Yes I have checked compression with a guage in all cylinders and hooked up a fuel pressure guage at the check valve on the back of the intake and all readings are to standard spec.
Jul 12, 2009 at 4:33 PM
