Well the iac part is true, but I cannot see how that is causing gasses to get into the cab, you may have an exhaust leak under the vehicle, address the idle air control valve and then have tthem do a safety inspection to check the exhaust system for leaks(holes)
SPONSORED LINKS
Wednesday, July 22nd, 2009 AT 3:10 PM
