1992 GMC S15 Freeze plugs
1992 GMC S15
SUSAN COBB
Engine Cooling problem
1992 GMC S15 6 cyl Two Wheel Drive Automatic
How many freeze plugs are there in this vehicle? Could replacing all but 1 or 2 of the plugs cause a transmission leak?
Apr 18, 2010 at 12:54 PM
HMAC300
  • 48,601 POSTS
tehre are 8 or 10 in the block and i each on each end of the cylinder heads. But replacing 1 or 2 will not cause a transmission leak unless you cut the coolant lines by doing it.
Apr 18, 2010 at 5:26 PM
