1992 GMC S15 fan belts
CHICAGODAMAN
Engine Cooling problem
1992 GMC S15 6cyl Four Wheel Drive Automatic
if the belt is routed another way than it suppose to , will that make truck run hot , or mess anything up . i have a belt on there thats a little short but didnt have the money to get right one ,, so now the heater wont get hot , and its steaming alot ;;; but no water is in the oil ;;;; i need your help ;;;;
Dec 9, 2008 at 5:32 AM
SWILLIAMS
  • 597 POSTS
If the belt is on wrong you a probably turning the belt the wrong way. That will cause problems and could damage the engine. Get the correct belt.
Dec 12, 2008 at 12:00 PM
