1992 GMC S15 fan belts
1992 GMC S15
CHICAGODAMAN
Engine Cooling problem
1992 GMC S15 6cyl Four Wheel Drive Automatic
if the belt is routed another way than it suppose to , will that make truck run hot , or mess anything up . i have a belt on there thats a little short but didnt have the money to get right one ,, so now the heater wont get hot , and its steaming alot ;;; but no water is in the oil ;;;; i need your help ;;;;
Dec 9, 2008 at 5:32 AM
SWILLIAMS
  • 597 POSTS
If the belt is on wrong you a probably turning the belt the wrong way. That will cause problems and could damage the engine. Get the correct belt.
Dec 12, 2008 at 12:00 PM
