1991 GMC S15 BOTH FRONT BRAKE DRAG
1991 GMC S15
147,000 MILES • 6 CYL • 2WD • AUTOMATIC
JWOSBORNE
BOTH FRONT BRAKES DRAG, I HAVE CHANGED WHEEL BEARINGS, BOTH CALIPERS,BRAKE PADS, BOTH ROTORS, BOTH BRAKE HOSES, MASTER CYLINDER. THE OUTPUT ROD IS ADJUSTED CORRECT. COULD IT BE THE COMBINATION VALVE THAT IS LOCATED UNDER MASTER CYLINDER,, WHAT ELSE COULD IT BE.
Apr 13, 2009 at 11:15 AM
  • 110,244 POSTS
Wow! you changed everything. THe only thing left is the proportioning valve.
Jul 1, 2009 at 11:48 AM
