1990 GM S15 2.5L TBI 700 Manual
Engine rebuilt 8 mo ago and running good until now.
ISSUE:
herky jerky under regular driving, loss of power, porpoising, erratic idle
Latest experience:
grounded the OBD1 ground wire A and turned distributor. vehicle ran well for 10 mintues or so.
Seemed like a new truck.
Shut down and came back 2 days later.
Vehicle wouldnt hardly start and went back to same as issue above.
Replaced:
Fuel Filter
cleaned gas tank and replaced fuel
new muffler
new IAC
new EGR
new Plug Wires
New plugs
replaced TBI gasket
Next item to do
Use timing light and lock down distributor
Any suggestions are appreciated .
What should I do if the setting of the timing doesnt correct the issue.
I appreciate help.
Possible ECM?
Is there somethign the ECM could lose causing this?
Thanks
ISSUE:
Latest experience:
Replaced:
Fuel Filter
new muffler
new IAC
new EGR
new Plug Wires
New plugs
replaced TBI gasket
Next item to do
I appreciate help.
Possible ECM?
Thanks
Mar 15, 2010 at 6:20 PM
