1989 GMC S15 starts and immediately stalls
TYLERW
Engine Mechanical problem
1989 GMC S15 6 cyl Four Wheel Drive Automatic
i recently did a motor swap on the truck. ran great, everything worked good, and now each time i go to start it all it does is fire and right away stalls, sometimes stays runnin for a short time when i pump the gas but then also stalls out, cant figure it out at all
Apr 11, 2010 at 3:18 PM
  • 75,988 POSTS
Start by checking the fuel pressure if its within specs and get back with the readings
Apr 11, 2010 at 4:06 PM
