1989 GMC S15 ignition coil
SHORTYMACK26
Heater problem
1989 GMC S15 6 cyl Four Wheel Drive Automatic
Need to replace the ignition coil on the truck. It will not start. Have replaced the distributor cap already.Can anyone assist with directions ????? Thanks
Sep 27, 2009 at 2:45 PM
HMAC300
  • 48,601 POSTS
you really need to take this to a pro otherwise you will be replacing part after part to get it to start. The mechanic can diagnose the problem right there and get you back on the road quickly and for a lot less money than you think......
Oct 9, 2009 at 3:34 AM
