1989 GMC S15 Fuel trouble
1989 GMC S15
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
MATTHEW NELSON
my truck is flooding and i have to floor it to start it. Could you please help me?
Mar 29, 2008 at 5:17 PM
Check the fuel pressure regulator could be leaking and injector/s stuck open
Mar 29, 2008 at 5:41 PM
KURTEE
I had the same thing happen to my 89 Jimmy 4X4.
It was the temperature sensor on the intake manifold.
When I plugged my homemade computer interface in the temp reading was showing -20 degrees and the fuel was pouring in.
I then disconnected the sensor and the car started running better.
Looking at the temp reading by the computer it showed -40.
Ha, open circuit meant that the computer put in a general fuel mix and that made it run better.
So I went to the auto parts store, got a new temp sensor and my problem went away!
Hope this helped!
Kurt...
Nov 16, 2008 at 10:40 AM
