1989 GMC S15 clutch problems
1989 GMC S15
100,000 MILES • 4 CYL • 2WD • MANUAL
RBH53
1989 GMC S15, with hydraulic clutch. I changed clutch, through out bearing (heard it called all kinds of things) so you may call it something else, and pressure plate. Also changed master and slave cylinders and lines. I bled them till I was blue in the face. The clutch arm (fork) moves but not enough. Could the bearing be on the fork the wrong way? I did not take apart just put together. Any help would be appreciated. Thank you
Jan 6, 2009 at 5:04 AM
DOCFIXIT
  • 18,828 POSTS
Thats a possibility but fork would move and there most likely be noise or engagement problem.
I know you bleed but these systems are a bugger to get air out. Push against the fork have someone pump pedal this will compress air and get it out. Hold and bleed. Repeat until good pedal.
Jan 6, 2009 at 5:25 AM
