1988 GMC S15 vacuum for 4x4
ASHLEY BERNARD
1988 GMC S15 6 cyl Four Wheel Drive Automatic
I want to know different reasons why the 4x4 will not ingauge in my 1988 GMC s15....
Mar 7, 2009 at 5:10 AM
  • 110,248 POSTS
Usully it is a vacuum related problem. Make sure the lines from the transfercase to the differential are in good shape. If everything looks ok, you may need to pull the hubs apart to see if there is a problem there. Also, check for a vacuum leak at the supply, the engine.
Let me know if what you find.
Jul 1, 2009 at 11:53 AM
