1987 GMC S15 throttle body injectors not spraying fuel
1987 GMC S15
ANDY213
Engine Mechanical problem
1987 GMC S15 6 cyl Four Wheel Drive Automatic
I bought the s15 blazer as is and trying to get it running again. I know the fuel pump is working ,but can't get the injectors to work.
Apr 11, 2010 at 11:19 AM
Check the injector fuse if okay get a noid lite and hook it up to the injector it should flash while cranking engine over
Apr 11, 2010 at 9:51 PM
