1987 GMC S15 Clutch
PHAZEL30
Drive Train Axles Bearings problem
1987 GMC S15 4 cyl Two Wheel Drive Manual
The clutch on my truck is not engaging and I have tried bleeding it several times what would be something that could be causing that?
Jul 24, 2010 at 3:27 PM
HMAC300
  • 48,601 POSTS
have someone to push the clutch in while you look to see if the slave is actually working or not. If it does work you could have a clutch gone bad or the clutch fork may have bent and isn't pushing the pressure plate in.......
Jul 30, 2010 at 10:37 AM
