No start with No spark -correct if so do below
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
SPONSORED LINKS
Monday, August 24th, 2009 AT 3:11 PM
