1987 GMC S15
ROTAXDUDE
1987 GMC S15
It has 206xxxKm maual transmission 2.5 4cyclinder. The problem is when i put the clutch in to come to a stop it always wants to die and sometimes it will idle back up. I had the plugs changed and air filter. How can i test to see if there's a problem? Thanks.
Sep 3, 2008 at 4:53 PM
  • 75,988 POSTS
Inspect and test the idle air control valve/throttle position sensor/EGR and PCV valves.
Sep 3, 2008 at 9:06 PM
