1986 GMC S15
89,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHIL W
My truck was running fine, then cuts off.. Won't restart. I wait about 30 min and its starts right up. What could be the problem.
Nov 1, 2009 at 3:12 AM
  • 75,988 POSTS
Next time it won't start back up don'tt wait do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Nov 1, 2009 at 3:31 AM
