1985 GMC S15 IGNITION COIL
ROCKCHICK
Electrical problem
1985 GMC S15 6 cyl Two Wheel Drive Automatic
No spark from coil. How do I test the coil and where does the power come from?
Apr 9, 2009 at 11:01 AM
  • 75,988 POSTS
Get a repair manual and check the primary and secondary windings resistances with a DVOM. The power comes from the ignition switch
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Apr 9, 2009 at 11:07 AM
