1984 GMC S15 emergency brake cable at rear backing plate
1984 GMC S15
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
BILL SOBJACK
I have had to replace the rear backing plates.Is there a tool to compress the spring on e-brake cable at the backing plate to re-attach the the lever arm to the cable?
Jan 8, 2008 at 1:16 PM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
No! I use 2 pair of sidecutters, put them together at the nub, spread the spring, hold and install lever, fairly simple!
Jan 8, 2008 at 1:22 PM
BILL SOBJACK
[quote:33e6ae22bd="merlin2021"]No! I use 2 pair of sidecutters, put them together at the nub, spread the spring, hold and install lever, fairly simple![/quote:33e6ae22bd] Thanks been tryining to do it bare handed with plyers.don't have side cutter's though.
Jan 8, 2008 at 3:22 PM
MERLIN2021
  • 17,250 POSTS
You can use any pliers, dykes work best!
Jan 8, 2008 at 5:03 PM
