1983 GMC S15 problelems in charging
JCASATALANO33
Electrical problem
1983 GMC S15 6 cyl Four Wheel Drive Automatic
i have replaced battery and alternator and still have something draiining the charge in the battery, how do i find the short
Nov 14, 2009 at 4:22 AM
JDL
  • 16,098 POSTS
welcome to the forum, check for any lites that may be left on, interior-- under the hood-- in the trunk-- glove box. Best time to check is in the dark. You can probably take a battery cable loose, use testlite between cable and terminal, if testlite comes on, there is a drain. You pull fuses, one at a time, till the testlite goes out, when you pull the fuse that effects the lite the most, the short is on that circuit.
The best way is to check for excessive amp draw, pull fuse till the amp draw drops to normal.
Nov 14, 2009 at 4:42 AM
JCASATALANO33
do i hook the test lite to positve or negitive terminal
updated 11-20-09
thanks one more problem when the car seems to be running for 20 minutes it starts to cut out and lose pwer like its not getting enough gas
Nov 14, 2009 at 4:49 AM
JDL
  • 16,098 POSTS
Don't believe it matters, use negative.
Nov 14, 2009 at 6:06 AM
JDL
  • 16,098 POSTS
[quote:edc2ee7a43="jcasatalano33"]do i hook the test lite to positve or negitive terminal
updated 11-20-09
thanks one more problem when the car seems to be running for 20 minutes it starts to cut out and lose pwer like its not getting enough gas[/quote:edc2ee7a43]
How long since a tune-up? If you think it is a fuel issue, start there. Change the fuel filter, check fuel pressure.
Nov 20, 2009 at 12:51 AM
