1982 GMC S15 Lights
PACKS_1992
Electrical problem
1982 GMC S15 6 cyl Two Wheel Drive Manual
Hey I am having trouble with my tail lights working when i pull out my head light switch but my brake and turn signalswork finewhat should i do
May 10, 2008 at 1:48 PM
MASTERTECHTIM
  • 4,750 POSTS
first check the fuse, if ok then you will have to check the brown wire going to the tail lights for power and see if you can find the wire broken somewhere.
May 10, 2008 at 11:38 PM
