1982 GMC S15 Cable opperated clutch
1982 GMC S15
PACKS_1992
1982 GMC S15 6 cyl Two Wheel Drive Manual
My 1982 S-15 pick up has a cable opperated clutch and we just put a new one in along with the stablizer or the thing that the cable from the clutch goes on to. Well anyway sometimes the clutch pedal works the other time u push in on the pedal and it goes pop. How can I fix this?
Aug 3, 2008 at 2:57 PM
You sure the cable is not kinked inside the cable sleeve-could also be the clutch throwout bearing is binding on the input shaft or the pilot bearing-
Aug 3, 2008 at 3:08 PM
PACKS_1992
Yea Im pretty sure we lubricated the throwout bearing before we put the transmission in. Is there anything besides the cable binding and the throwout bearing
Aug 4, 2008 at 2:28 PM
