Whining (gear?) noise when car is turning and accelerating
GMC
IMIND
Hi. I have a 2002 Pontiac Bonneville.
There is a whining noise when I make a turn (right or left) and accelerating (pressing the gas pedal). This noise sounds similar to noise in low gear from a car with a bad gearbox in the old days.
If I turn but let the car coast, or when I am braking, then there is no noise.
Does anyone know what the problem is and if it should be fixed immediately?
Thanks a lot. :roll:
Jan 19, 2006 at 11:58 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Provide any existing inspection findings and clarify where the noise was heard during the previously reported episodes.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
FIZZAK
  • 15 POSTS
CV joint? But hard to believe it would go bad on 2002 unless you have high miles or a broken CV boot to let dirt and water in.
Jan 20, 2006 at 2:16 AM
Discussion summary
The owner of a 2002 Pontiac Bonneville reported a whining noise while turning in either direction and accelerating. The noise was absent when turning while coasting or braking.
Reported outcome: The owner did not report a diagnosis, completed repair or resolution.
A reply suggested a CV-joint issue, but no findings confirmed it. The source does not establish the cause or whether continued driving is appropriate.
Read the original discussion
